spankybear
- 946
- 93
- WA
I think you would be better off getting group 24 battries. That is what I installed They will fit in lengthwise and with a little work the cables will fit. I got blems from Interstate batteries.
The batteries will fit in just find but be a bit low from what I'm told. You will also need some ratchet strap or something else to hold them down. The main battery cable is very flexible and you should be able to route it easy enough.I am in a different situation. I am going to fly in a retrieve a truck with a 1000 mile trip ahead of me.
The truck will jump start but I want to replace the batteries with group 31s for the long trip. Is this a straight forward to replace 4 original military batteries with 4 group 31s?
Thanks
Yes you will want to go with 4 group 24 batteries. I believe I got group 24F batteries. Everything is the same but the - and + post are swapped. Should not make a difference as long as they are all the same (all 24 or all 24F). I believe Johnson Controls makes Walmart batteries. In my opinion Johnson Controls makes the best batteries. They also make interstate... I tend to stay away from any battery made by Exide as I have had nothing but bad luck with them.Will the group 24s or group 31 be more straight forward install.
If I go will group 24s is it 4 of them also?
I am tempted to go with group 24s from Walmart because I can return the cores to any location. (and the Walmart warranty)
The interstate batteries locations all seem to be independently owned and will not except cores from others stores. They also want a $60 core fee for each used battery (not blem)...a waste of $240 in cores since I will be 1000 miles from home.
Thanks for the help
The 24F was made for Ford since the positive post on the 24 would be next to the body and could short out. So they had the post swapped so the negative would be next to the body. The post are not centered front to back. It makes no different in the LMTV battery box as the post will not be next to the body. You just need to make sure they are all the same either 24 or 24F. The size of the battery is exactly the same. The positive posts will be towards the inboard or center of the truck. There is room to slide the battery front to back in the truck. If you have a 24 you can more the battery one way or if you have a 24F you can slide the battery the other way front to back. The reason I went with the 24F was that is what Interstate had blems of and at 35 bucks a piece and 15 dollar core charge it was the cheapest way to go.I just want to confirm that the 24F has the terminals on the correct side versus the group 24.
Does anyone know for certain? I plan to get the Uber to take me to Walmart directly from the Airport before getting to the truck.
Thanks again
curious what mods does it take to do six 24f batteries?24F, either 4 or 6 of them. 4 will fit without having to modify the box.
[Elmer Fud voice] vewy intawesting [voice off] bet some folks would love to see the wiring schematic (or picture) for that setup. any particular reason 24f works better compared to 24standard? again much thanks.Cabling..[image] and trimming the box
of the group 24s?... well price for one I got all 4 including the core charge for the price of one 6TL. Also availability... you can get the 24s anywhere the sell batteries...devils advocate..... what is the advantage?
sorry my bad.. poor communication. Let's try againof the group 24s?... well price for one......
the advantage is to for a general reason of adding more capacity to the system that's the short answer.sorry my bad.. poor communication. Let's try again
What is advantage of six 24's over four 24's?
wellll..... There is always a point of diminishing returns which is the Devil's Advocate point I was leading toward... what practical value is there in the increased capacity/reserve; except being able to drive further if your alternator goes out? (that is if the alternator does not direct power some things) I guess if you had a 24v air conditioner it might be of value as well? Am sure there is something that makes it a value tham am just not seeing.the advantage is to for a general reason of adding more capacity to the system that's the short answer. .....
Adding a AC unit really will not effect Reserve Capacity or Cranking Amps. It's more for if you want to run things when you are not running the engine. If you have a camper on the back you can run on battery longer and still get your truck running. It's like a fuel tank... the more capacity you have give you longer run times... Also with cranking amps you will start the truck easier in cold weather. More will make the truck turn over eiser on a very cold day...wellll..... There is always a point of diminishing returns which is the Devil's Advocate point I was leading toward... what practical value is there in the increased capacity/reserve; except being able to drive further if your alternator goes out? (that is if the alternator does not direct power some things) I guess if you had a 24v air conditioner it might be of value as well? Am sure there is something that makes it a value tham am just not seeing.
