What is this?
Floridianson
2,503
Interlachen Fl.
That is to be used in extream emergencys. That is the cab boost line and the line to the intake manifold is not hook up. In extream emergencys like you need to double your speed or your passenger has diarrhea they can open it up and it gives you 110 lbs of boost. It is a one time use only though sorry.
rustystud
2,987
Woodinville, Washington
That was funny ! rofl
tommys2patrick
272
Livermore, Colorado
It’s on the inside, passenger side firewall. I also believe that it chatters like crazy when it’s below zero outside.
Auxiliary air connection point. There is a valve to open or close the end of this air line. there should also be a brass screw-on cap for the end of this line connected by a short chain so it does not get lost. the cap could be loose and the valve partly open leading to the chattering you mentioned. your picture is not clear enough to tell what is on the end of this line. perhaps someone has installed a screw on quick connector for an air line and it is leaking. you might be able to find information about it in the operators manual. available on this website if you don't have one.
Scrounger
66
Southern, Maryland
That is a fitting for an air line to inflate tires. Later trucks didn’t have them since they started getting air lines with a glad hand. The early BII had an air line with a fitting. The trucks we had when I was active duty were mostly made in ’62 and ’63 and had that fitting.
WillWagner
2,758
Monrovia, Ca.
Yup, My truck came with the quick connect fitting and a 20' aeroquip hose with tire filler. It worked great.
winfred
10
port allen la
my 53 reo has the airline under the dash with a capped valve on driver and pass sides. planning on using it to run my air horns as its handy and already has a valve to isolate the modifications to the air system if needed
ThinkBig
Sheboygan Falls Wi
That makes perfect sense. Mine is a 69’ and has glad hands. Maybe they put them on longer than thought.
doghead
4 Star General /Moderator
1,179
Pretty sure it's descibed in the -10TM.
