Different LMTV canvases?
Awesomeness
1,518
Orlando, FL
How many different canvases are there for the LMTV? When I was in the Army, I remembered that the forward side flaps were on top of the rear side flaps, but the current canvas I have for mine is the opposite (so the rear side flaps catch the wind and balloon out).
Mine is stamped "19207-12420281-015 MFR-0V8C5".
DiverDarrell
24
Port orchard, WA
Can’t you reverse the canvas? Just a thought. Should have the same end flaps both sides. But it’s been a while since I have had mine rigged up
DiverDarrell
24
Port orchard, WA
Not thinking to inside out it, but rather rotate it 180 degrees. I thought I had the same problem when I first put one on, and then I rotated it and it worked. I have two canvases here I’ll try and find numbers on when things dry out to see if they match yours I know one will be different as one is tan and the other camo. I’ve had 3 tops since I have had my truck and they all were able to have the front flap cover the rear. Maybe you have one sewn on a Friday afternoon of a long weekend, as these were made by the lowest bidder.
Awesomeness
1,518
Orlando, FL
Oh, I see. Umm, yes, you probably could, with a few issues. The pull string to raise the "rear" flap would then be in the front, and then the front flap and rear side flaps would be facing into the wind. So it would end up with twice as many flaps facing into the wind.
scottmandu
36
Texas
As far as I know there are two different tops.. Cammo and Tan. I've had a dozen new ones at one time and that many used ones and they all have the flaps pointed rearward.
Awesomeness
1,518
Orlando, FL
I'll take a picture of mine when I have it on the truck again (I took it off a few weeks ago while offroading, so it wouldn't get raked by trees, and haven't put it back on yet.) The rear side flaps are clearly manufactured on top of the front flaps, so they scoop air while driving.
scottmandu
36
Texas
Perhaps they were made wrong?
Awesomeness
1,518
Orlando, FL
It doesn't appear to be a mistake. The flaps are shaped differently than the typical "front side flaps on top" version, it doesn't have the black circles reinforcing the corners (they are tan), etc.
When I bought it, I was told something like "This is the later Afghanistan version, where the rear flaps scoop air to keep people in the back cooler." I didn't really pay much attention to it at the time, but now I find it annoying. The guy could have been making stuff up, or there might have been more to it.
coachgeo
3,461
North of Cincy OH
Have sewn into the flap a bungee cord or even load binder strap orr??? that you can use to cinch down the flap.... when you do not want it to scoop air like hwy road travel or off-road when you do not want tree limbs grabbing the flap etc. Unhook/ un tie the sewn in piece if you do want to scoop air... like when people are in the back or??
Awesomeness
1,518
Orlando, FL
It has the D-rings sewn into the bottom, and the rubber bungee, as well as the straps and buckles across the seam on the inside. So you can get it held down mostly ok, but it will still bellow out a few inches when going 50MPH.
coachgeo
3,461
North of Cincy OH
buttttt..... once it is bellowed.... wouldn't it possibly be no longer be an air scoop... but more of a air deflector?
Another thought is.... before you cinch it down..... put pool noodle or pipe insulation inside then cinch it down. You will have a bump/wind deflector?..... but not a scoop maybe?
