Glockfan
- 14
- 18
- Brigham City, Utah
I actually stole Sharecropper’s idea when I decided to go with the replacement joint. Not sure which one he went with but I chose the chrome moly steel “racing” joint. Initial impressions are very good. It is a $100 part but there will be no room for slop in the linkage. The little steering coupler has a very high quality needle bearing U-joint in it. One side fits the 30-spline steering box and the other is 1” DD. Should be exactly what I need. Here are some pics.Interested in the steering shaft upgrade, I was thinking of getting a steering shaft from an XJ at a junk yard. What are your thoughts on that vs the new linkage you got? Does this bolt onto your existing steering shaft?
![887DB481-ED8A-4F0B-84D0-D2788191E146.jpg 887DB481-ED8A-4F0B-84D0-D2788191E146.jpg](https://www.steelsoldiers.com/data/attachments/502/502496-0498e7360e09046f168521450f1eb07f.jpg)
![2E8429E1-0E5D-47D4-BDAD-B7C9E3489B40.jpg 2E8429E1-0E5D-47D4-BDAD-B7C9E3489B40.jpg](https://www.steelsoldiers.com/data/attachments/502/502497-8fab5d10689684f26f1a6d3125126050.jpg)
More to come...
