Propane Carb Conversion, Hobart Welder/Wisconsin Engine
MatthewH
Boyne City Mi
Has anybody converted the Hobart G-204 welder that comes in the M-887 service body from gas to propane? I have a low hour unit I use mainly for backup 120v power, and mild welding I'd like to convert, and having a hard time finding a kit.
The welder itself is powered by a Wisconsin VG-4D 4cyl engine. I don't use it as much as i used to, and even with rec/ethenol free gas and running the engine out if gas still seem to have carb issues from sitting
Thanks
MatthewH
Boyne City Mi
I have an email into them, with some general question's about there kits and setup.
Was hoping somebody had traveled this path already, or had a used setup they were looking to sell so I could pick there brain
snowtrac nome
139
western alaska
Those welders have a control box that if frequency gets to high or low they will blow the box and parts are not available anymore and that was back in the late 80's. when they run right they are an awesome welder, but I like the diesel models much better.
CMPPhil
376
Temple, NH
Hi
Another source for propane conversion unit would be forklift repair or sales outlet. Hospital I worked for years ago searched for a propane conversion until, tried all the normal generator dealers they wanted to sell them a new generator, the forklift outfit wanted to know displacement, RPM and came up with a conversion unit.
Just a thought
Phil
MatthewH
Boyne City Mi
Only issues I've had with the control box was the relay on top was bad when I first got it. Other than figuring out how the box worked and controlled the ignition system, haven't had any issues so far.
Parts do seem difficult to source, most generator side stuff seems to have to come out of Canada, and off Ebay. Naturally Miller doesn't support older Hobart equipment anymore, except for manuals, they did send me the correct manual with parts lists and diagrams.
MatthewH
Boyne City Mi
Hi
Just a thought
Phil
Hadn't even thought of checking with a forklift company. There's a couple semi local I'll have to stop in and ask
