- 1,813
- 1,519
- Orlando, FL
My truck is missing the black plastic cover off one interior door handle, and the other one was replaced somewhere along the line with a broken window crank handle. So I decided to 3D model some handles that could be machined from aluminum as inexpensively as possible (still not as cheap as I'd like, because it's complex geometry, but I did my best). I also 3D printed one to test fit, and it's pretty sturdy... I think a 3D printed one would work just fine (as I have it now, the splines fit on pretty tight - tight enough that you really have to push it on there or use the bolt to pull it on).
I just wanted to see if these things being missing or broken is a problem others have too, that is worth solving on a bigger scale (e.g. having a batch of aluminum ones made, posting the 3D printer files, offering 3D printed ones for sale, etc.)?
Concept rendering:
I plan to do the same thing for the window cranks as well.
Concept rendering:
