Did you lift your bed when you added 16.00's?
Buffalobwana
179
Frisco Texas
Common sense would tell me to lift the bed 2" since you added 4" of tire. Also, since 14.00's rub the bed slightly, how about switching that 1x board that is between bed and rail now, for a 4x4?
I saw a pic from 98G where it was done. Anyone else do it?
Buffalobwana
179
Frisco Texas
Yeah, someone responded to a thread earlier this week about clearance. Said that with no load in the bed of his 923(A2?), his tires rubbed lightly at full articulation.
Mos68x
36
Seligman,AZ
I had asked how much articulation there was before I got my truck. Once I got it home though I quickly tested it and with both rear axles going opposite directions there definitely was some tire rubbage on the bottom of my cargo bed. If I roll 16s like I want to then I would certainly put a 4x4 in place of that 1x4 spacer.
lindsey97
17
wynnewood, oklahoma
weeds_artic 001.jpgweeds_artic 009.jpgweeds_artic 004.jpgweeds_artic 003.jpg
I have installed 16.00 r 20's on only one truck; a M923A0, and the tires barely touch the bed, at max articulation, with NO LOAD. Been running them for 2 years now, with zero issues.
I have heard but NOT confirmed that the Marine ISO beds are built "taller" and will clear the 16.00 r 20's better than the regular dropside beds, with no additional wood added to the marine bed.
4XDesign
49
Blythewood, SOUTH CAROLINA
Maybe I was just hard on the old 923 I had 16's on but I could get the tire to bite the bed hard enough to briefly pause rotation. Lifting the bed sounds like a great plan.
simp5782
Feo, Fuerte y Formal
9,486
Mason, TN
Interesting thread! I'm curious, has anyone tried this on an M936 wrecker, and if so, what all is involved in lifting the bed on one of those?
You would run into shaft angles on the 809 series trucks. It would also put the center of gravity higher on the truck. It would break the securing u bolts as well I am sure. Especially on a side lift. You would be amazed at how much they flex. With a 4x4 piece of wood something would snap.
Sent from my SM-G965U using Tapatalk
Mos68x
36
Seligman,AZ
I’m going to have to put in a 4x4 in place of the current 1x4, there’s just no way around it for me since I had engineer the ISO frame out of 8” C channel and I beam (cost, money, & weight) vs using 10” or 12” material. I’m going to make up the difference between the 8” and the current lift of the bed with a 4x4, however I will taper it like the original one is so that there is still enough flexibility in the chassis to avoid breaking costly parts.
simp5782
9,486
Mason, TN
So in other words, this would not work on a wrecker variant, at least without substantial re-engineering of other things as well?
If you want to see how much a frame on these trucks can flex check out my video with the JD710 back hoe climbing a mountain. My frame flexed so much under the torque and load that you can see the bed of the truck tilt to one side. That was from the flex and it actually kicked the 4x4 out from under the bed frame rail It had all its bolts in there and the 4x4 had lag bolts into it with steel pieces to keep it from walking to the inside. It stripped those right out of the 4x4s and tossed the it under the truck and the bed dropped back down.
One reason those springs are on the front bed bolts is to account for the frame flex.
71DeuceAK
438
Fairbanks, Alaska
In a way, I'm maybe thinking I shouldn't mess with it, as the original engineers knew what they were doing in terms of calculating frame flex, distribution of tension/stress/weight/etc and I don't...
Brutacus
208
Marion, AR.
Are you asking about something like this? My truck had 16.00r20s, a deuce bed, and frame extension welded to the back when I got it. It did ok, but my truck is an M818 with a shorter frame. Shorter frames with no weight on them don't flex as much as the longer ones.
Buffalobwana
179
Frisco Texas
They didn’t think we would put 16.00’s on it either. That would just be plumb stoopid!!
Buffalobwana
179
Frisco Texas
If you don’t raise it, do your tires a favor and weld a nice wide piece of 1/4” or 3/8” flat steel where the tire would normally bite the bottom of the bed. At least this way you won’t loose chunks of your tire to the bed frame.
