USAMilRet
- 15
- 18
- Tampa, Florida
Fuel pressure is 7.9 PSI measured at the connection at the electric fuel pump at start and after start.
Oil sending unit shows 240 ohm as needed when shut down but when the engine is started and allowed to run, the resistance only drops to 200 ohms not to the 100 to 33 ohms level indicated in the manual. However, this does not mean that the sender unit is bad IF the oil pressure from the engine is only 5 to 8 PSI. So how do I find out the real oil pressure? If the oil pressure is really that low, it has to be adjusted at the pump inside the crank case. Further testing needed.....
The fuel solenoid is bad. It will only retract now if helped. Once deenergized, it has to be helped again to retract. While in the retract position, it moves a little and will not hold position. So this need to be replaced. Part number and source availability?
