Steel Soldiers MV of the month 2018 - July VOTE HERE!
73m819
325
gainesville, ga.
Need a knowledgeable response here.....
A Member has PM'd me, apparently unable to VOTE via Tapatalk.
Here is our PM exchange....
Be blessed.
John
(End quote)
So, can anyone render some concise instructions for all to benefit from???
Thanks in advance.
John
Since STEEL SOLDERS is a INTERNET site, designed for COMPUTER not PHONE access to the internet, with allowed other non-designed access which means that just because you are using non-designed access to access SS, does not give anybody the right, thought, reason to believe, ect. that you should get the the total access that DESIGNED access would give, if someone can get get designed access with NON-designed access then GREAT, if not O-WELL.
USAFSS-ColdWarrior
Chaplain
5,847
Since STEEL SOLDERS is a INTERNET site, designed for COMPUTER not PHONE access to the internet, with allowed other non-designed access which means that just because you are using non-designed access to access SS, does not give anybody the right, thought, reason to believe, ect. that you should get the the total access that DESIGNED access would give, if someone can get get designed access with NON-access then GREAT, if not O-WELL.
Thank you, Sir!
Sometimes work-arounds never really get the job done, huh? There's something about the "right tool for the job" going on here. :goodjob:
