JOR
- 0
- 1
- kingston ny
Passenger side rearmost axle leaking air from the CTIS brake. Pressure dropping exceedingly fast when the brakes are applied.
The leak is coming from inside the brake drum. The brake drum doesn't want to come off. Is there a way to get to the ctis from the back or do I need to remove the drum to find what is leaking? I can't locate this in the manuals.
What can be causing this leak, and how do I go about locating it, since I'm having trouble getting the drum off?
