Blackout toggles do nothing
KI4FKW
Alabama
All of the blackout lights are present in my truck. The toggle switches are there. All of the lights are physically plugged in behind the bumpers. However, the lights do nothing and the switches do nothing in any configurations. Is there any sort of commonly used way to disable the toggle switches that you guys use? I’d like to have everything back in working order. I searched, but may have overlooked a simple answer.
cucvrus
10,434
Jonestown Pennsylvania
Using a test lamp check if current is going to the lights at the bumpers. They should have current in B/O and also the B/O drive lamp in the grille is probably rusted beyond repair. The grounds on every light need to be cleaned and re-grounded to a clean surface. I am sure you will break the studs that hold the B/O lamps to the brackets on the bumper. Good Luck.
MarcusOReallyus
816
Virginia
Folks, if the BO light switches don't disable the running lights, the most likely explanation is that the switches have been deliberately bypassed. Even if someone cut out all of the BO lights, the switches would still disable the running lights.
KW, can you clarify if the switches disable the running lights? OR, are you saying that the BO lights won't come on when they should.
KI4FKW
Alabama
I get that.
Toggle switches do nothing at all. They don’t enable or disable anything in any configuration. I assumed that they have been bypassed, so I was asking if there was a commonly used method to bypass them so I would know what to look for.
nyoffroad
690
Rochester NY
Stupid question, are you sure the BO lights aren't working? If you've never seen them in use in the military then they may be on and you wouldn't even know it, to make sure check them at night and look in the 'cats eye'. Just hopeing thats all it is.
KI4FKW
Alabama
Yes, I’ve checked them at night. Even so, the toggles don’t kill the headlights in any configuration I’m sure the switches are bypassed. I just gotta dig to find out how and where.
porkysplace
1,493
mid- michigan
Have you pulled the switches to see if there are any jumper wires .
MarcusOReallyus
816
Virginia
Yep. That's where you need to go next.
Once you get the dash panel off (just a few screws), you'll find 4 pop rivets holding the switch mount to the dash. They have to be drilled out to get to the switch connections.
But, I'll be you will have nice shiny new ones, or maybe something else holding them. I'm betting you'll find they were bypassed. If you do, please post some pics of what was done, so we can all see.
cucvmule
collector of stuff
1,155
591
Crystal City Mo
Yikes, ok do the headlights and parking lights work properly when the headlight switch is pulled on? Yes, then the service light switch is either toggled up or it is bypassed completely somewhere by the toggle switch. Leave headlights off, right toggle drive lights down then left toggle blackout on go up and let go back to center. Now all blackout lights on until you toggle left toggle down, toggle returns to center, all blackout lights off.
Now all lights off until right service light switch is toggled up and stays there. Now headlight switch works as it should like civi truck. I just went outside to look at, also under dash and you can see clearly under without much heartache to see if wiring has been molested at toggle switches. Grounding wires are very important in this wiring setup as there is no metal contact as all blackout lights are plastic. cuvrus has very good advise and use test light to verify that you have current as afterall they are plastic and 30 plus years old. Good Luck
porkysplace
1,493
mid- michigan
Proper operation of the switches is also covered in the -10 TM
KI4FKW
Alabama
Well, I go look under the dash and see that the rivets are stil in place, both switchhes are there, no obvious jumpers (I’m no expert).
View attachment 737413View attachment 737414
As I go to get up, I notice something tucked up over some wires....
Now that I look I notice the left switch is not original.
Looks like I have some figureing to do.
The switches still appear to do nothing.
porkysplace
1,493
mid- michigan
As I go to get up, I notice something tucked up over some wires.... View attachment 737415
. View attachment 737416
Picture #1 shows a blue splice and any of them will give you problems , they usually cut the wire the are spliced into and always corrode . I consider those connectors a last resort , even the ones with silicone in the are a last resort.
KI4FKW
Alabama
Yeah, I see it now. There is another one too.
I know now that they have bypassed the switches. My next feat is figuring out what the left switch goes to to see if I. Can eliminate it and undoing the bypass.
The only thing on the truck that I have found to be electrical and unoriginal is a trailer brake controller. No evidence of old fog lights, radios, or anything else so far.
KI4FKW
Alabama
