- 12,195
- 319
- 0
- gainesville, ga.
For you that have HEAVY 39/809 series 5ts (wreckers, ect.,) here is a BETTER way to shift to save the clutch. As you KNOW the trans suck especially the overdrive, though the non-overdrive is not much better. The wreckers are close to the 36,000 lb. mark, loaded can be a easy 60,000, the trans has a hole between 3rd and 4th that the whole truck could fall in, 2nd to 3rd has a hole but about 1/2 as bad. The clutch is a SINGLE disk, the trans puts to much load on a single disk (should be a DOUBLE) when taken the load, which REALLY shortens the LIFE of it in HI. The way I found to get around the crap trans and a single disk at the same time is to start out in 2nd L, then 3,4,5 low, then drop from 5 to 4th, shifting to HI at the same time, then 5th. BY doing this the starting load on the clutch is GREATLY reduced, ALSO the BIG hole between 3rd and 4th is about gone. This may take some practice, but after a bit shifting will have NO missed shifts and be as smooth as (you fill in the blank), You WILL notice a difference for the good. This is just a suggestion, try it, if you like it GOOD, not like it, nothing lost.
