MEP-002a & MEP-003a fuel pumps
rustystud
2,793
Woodinville, Washington
This is just a heads up for all us MEP-002a and MEP-003a owners. Check your fuel pumps ! I had not checked mine since I bought them over 5 years ago. After all they worked just fine, and I replace my fuel filters every year. Last weekend I thought it would be a good idea to take out the redundant pumps and store them away just in case, since new pumps cost about $150.00. After I pulled the first one off I decided to clean out the filter. WOW the rust I found ! In fact it would soon close up the inlet port. Now I use good fuel, but I don't have a filter from the tank (250 gallon) to the generators. So after finding rust in the one, I checked all the others. Again rust found. Cleaned them all up, and put them back into service. I'm now going to put a water/fuel filter inline from the tank.
Buttweet
Fort Valley Ga
Are all three fuel pumps the same p/n and can the aux pump (which I never use) be substituted for one of the other two? Thanks for your response
Buttweet
Fort Valley Ga
Oh, one other question, since all three fuel pumps are the same, why is the aux/prime pump louder than the prime pump when they are switched on? Thanks for a response.
jamawieb
541
Ripley/TN
Because there is no fuel in the pump to prime. After its prime, it sounds the same as the others.
