coachgeo
- 3,405
- North of Cincy OH
so not to hijack another's thread..... starting thread here.
Ambo inverter was removed prior to sell so I could just as easy install a 24v-->110 inverter formerly where the other 12v one was. Useing inverter to power a cheap 110v AC unit and other 110v items. Then install step down to 12v sent into wiring of the OEM Ambo 12v system. (LED lights mostly, a few 12v sockets and a few fans). My portable liquid chiller unit (24v) and my stationary chiller unit (110v) can be used to chill sleeping cover(s), cool vest(s), poncho's etc for inside or outside use when it is more logical to just cool the person than a whole space. The 24v chiller will cool person(s) in the cab and ambo when driving. Just do not see logic in cooling whole cab or aluminum box compared to just the person(s) when your in reality just sitting inside them seat belted for long periods of time; not getting up and moving about.
Plan is for solar to also aid in powering my small home (1000w). Due to cost of batteries, have not decided yet on charge controller. Either a medium sized bank of battery for ambo and a controller that has a grid tie feature to defray power cost int he home or a larger bank that the home and/or ambo can use. I prefer the large bank... but cost esp. when factoring in annual battery replacement..... grid tie seems more logical, at least according to my friend with 30yrs in solar industry
Have a NOS military diesel fired coolant heater. Pretty sure it is 24v ignition too. It is NOS for a Duec? Plan to install in similar manner to how Eberspaecher's are are plumbed into overland truck habitats. Example plumb in ability to use it for engine/cab warming along with habitat radiant/blown heating along with small tank for hot water warming. Maybe also personal heating using above described chiller's plumbing system .
What is ya'lls suggestions on this......
Also please post what is your plans and why
Am puting former ambulance box on back of mine for habitat. Going 24v in habitat for consistency such as using the habitat battery bank to keep truck battery OEM wired bank topped up. Also my cab AC (actually a liquid chiller) is 24v. Granted this plan came about while I assumed the OEM truck battery bank was charged via the 24v side of the alternator but now understand it is 12v charge side. (or am I still misunderstanding how the FMTV alternator charges the 4 batteries?) It draws so miniscule amps (4ams at 24v) compared other options and will be massively easier and less costly to install it for cooling cab occupants compared to typical AC ..... It is by no means and apples to apples comparison. If you need starting batteries and you are not putting a living space in the back the battleborn would be ideal because they are a simple drop in replacement.
