Okay all, its fixed!!! After reading and re-reading all of your posts I traced the wire off the x-terminal and through the K20 relay. I had 24V everywhere I was supposed to and just about to give up again when I happened to wiggle the wire off of the #6 terminal of K20. As I wiggled it, the wire popped out of the terminal fork (proper term?) and revealed a little corroded wire end. Despite having checked that terminal 20+ times the current wasn't actually getting into the wire and then up to the x-terminal. 20 seconds later I installed a new end on the wire and the AC interrupter switch roared back to life.
Thanks to this forum and all those that make it go around!
