DW Fording switch
riderdan
20
Central Kansas
So at some point in its life, my HMMWV had a fording kit installed and then later removed. The hole in the dash where the switch used to be was filled in with a huge, ugly blob of body sealant. It looked pretty hideous so I removed the blob. But not there's a hole that lets in heat from the engine compartment
I eventually plan to install the DWF setup, but money is tight at the moment. In looking around for something to plug the hole, I've found a few plastic plugs that would fit, but I'd prefer to just throw a fording switch into the hole. I haven't had any luck locating the switch except in the whole kit.
Anyone have a line on these?
TIA
Retiredwarhorses
4,184
Brentwood, Calif
Only marine and navy trucks got fording kits, the hole is there from the factory for all hmmwv’s.
there is a lot more to the kit then the intake, exhaust and a valve.
riderdan
20
Central Kansas
And there's my dilemma. I think it's cool but it's not really how the trucks I used to drive were set up... I'll have to noodle on whether or not I want to do something that's definitely not early 90s Europe/Gulf War authentic. Do you know how the holes were plugged originally? None of my pictures from my time in service shows it, and my memory for details stinks. I don't definitely don't remember a big blob of sealant...
I realize there's more to it than the switch, intake, and exhaust. I haven't seen one recently (partly because I haven't been looking I suspect) but the full setup with all the associated hoses, caps, etc has been on eBay a few times. Which is another aspect of my dilemma... not only is it not "authentic" but it's a hassle to install. Here in flat-as-a-pancake Kansas, I don't think I'd ever put it to real use.
Action
1,558
East Tennessee
Holes were filled with plastic caps. Look at the outside of the left fender. There should be 4 big plugs where the fording exhaust would bolt it. The caps usually get painted over and may look like smooth rivet heads.
papakb
1,185
San Jose, Ca
I installed a keyswitch in the hole to disable the start system for security. Think outside the box as to what it could be used for.
NV555
Ely and Vegas Nevada
The switch there looks like a battery kill switch that you would use to kill power coming from the battery on a truck. Also for deep water the engine has special dip sticks for the oil and trans. Of course it requires a special tube for both of those as well. I’m sure there are other things as well. Cool project for a weekend +++++
might look like like the starter switch but bigger.
Would make a great great place to dump contraband out of the vehicle if being chased by the sheriff lol. I don’t think many HMMWV owners would have contraband.
