Hello forum.
Finally I got my M1078 from the dealer and starting the RV conversion. But for first I have a problem with the cab latch. The hydraulic latch is working well (tried it with cab fully raised, it engages and locks the hook), but when I lower the cab the pin would not go in and block the hook.
I attach 2 pictures, for me seems that the upper and lower part are not straight mounted and the cab did not go down or straight enough to engage the lock. On the manual I see that there are 2 spacers, I think they are installed. Can I remove them, even if I have my truck is < 7167? Are the latch brackets all the same? 3th screw is missing, so something was done before...
Thanks and kindest regards from Italy! And sorry for my english...
Christian
Christian
