sandsjh
- 2
- 0
- magnolia/ar
Hello:
I searched and did not find the answer -> https://cse.google.com/cse?cx=partn...ers.com/forumdisplay.php?115-5-ton-and-up-TMs
Issue: Only a click when turning the key on. No action when the engine start key is pressed. All instrument panel lights, buzzer, and crash avoidance LEDs work.
Issue #2: Transmission box doesn't light up to be able to switch it into neutral
So far: batteries checked by a local (non-chain store) dealer - all are good - 25.63 volts using the end posts
All ATO fuses are good.
All ATO circuit breakers check continuity when pulled
Main goal: get the transmission into neutral so we can pull it out of the fire station
I have the 1500+ page manual.
m915_TM 9-2320-273-20.pdf
TM-9-2320-303-24P.pdf
VIN 1FVXAU0072PK01136
CONTRACT #: DAAE07-98- D-S001
ENGINE MODEL CUMMINGS NTC-400 BIG CAM
TRANS MODEL ALLISON AUTOMATIC HD-4560P
TIA
TIA
