Break-In oil for the low hour MEPS
jcollings
391
Jupiter/FL
i don't think just because a unit has been through reset means the engine was new or rebuilt. also the hour meter may or may not be correct for actual engine hours because it could have been replaced. and i am unconvinced that the john deere oil we have available to us is the same as the gov spec oil because the TM on the engine says not to use a 10w oil. in my opinion if i thought i had a true low hour machine i would add some zinc to regular 15w 40 and go on from there. i am not OCD about the break in anyway. just an opinion
Sent from my SAMSUNG-SGH-I317 using Tapatalk
jcollings
391
Jupiter/FL
Run the JD plus break in oil up to a 100 hours just like all the previous post described you'll be good. run it hard under load 75% to 100% make it work during that hundred hours.
Daybreak
2 Star Admiral
770
Va
Howdy,
OK, they also might have access to Lister-Petter break-in oil.
OCD about break-in?
Any person which has rebuilt or has torn apart a engine will tell you that the beginning running of a engine is critical to its overall life. I guess the military spec for running break-in oil is just hearsay.
John Deere break-in oil is a 10w-30 non detergent oil with additives. It is a tinge greenish color.
Standard diesel 15w-40 oil is detergent style.
Oh, the military uses it. :D
View attachment page 20 TB 11_6115_741_24.pdf
justacitizen
40
oklahoma
Howdy,
OCD about break-in?
Oh, the military uses it. :shock:
T
Thank You. i am not trying to be argumentative but let me ask a question. the TM specifically states not to use 10W30 oil so that leads me to believe that the " John Deere "oil that the military buys isn't the same as what i can get in the dealer??? the lister info says the same,"not to use 10W30" oil unless the temp is really cold. why would lister contradict itself? does John Deere make 14W40 break in oil?
Daybreak
2 Star Admiral
770
Va
Howdy,
The standard operating procedure for a generator in the field is to use what is issued. 15w-40 oil for oil changes etc... Artic service calls for other oil weights.
Coming from the factory or DRMO reset, the factory fill is break-in oil. Tags stating change after 100 hours. Break-in oil is not found out in the wild. The regular staff in the field has what is issued.
The guys at the DRMO just know when they rebuild a engine they use this hose with a meter on it to fill it with oil and put tags on the engine and S-1 switch saying to change the oil after 100 hours.
John Deere Break-In Plus comes in one flavor 10w-30, non-detergent with additives for the reason of breaking in a engine.
Dewie38? What was the factory fill coming off the line?
Daybreak
2 Star Admiral
770
Va
Old thread but wanted to let everyone know that Joe Gibbs Driven has a 15w40 diesel breakin oil that is only slightly more expensive than the deere oil.
Can get it on Amazon and other places
I've seen it for $29 as well
Looks to be twice the price.
John Deere Break-In Oil can be purchased at any Deere Dealer. Green Ag equipment, or Yellow Construction equipment, or even online.
BeerCan
Rhea County TN
Not really. I went to 3 different JD dealers today and none of them have it. 2 never heard of it and these were not small dealers (ag pro)
Also it's $30 at greenpartstore, and $28 at greenfarmparts with a minimum of 16 dollars shipping ($30 direct from JD as well)
So hardly double at $36 with free ship, but if you can point me to where I can buy the JD stuff for $18 dollars a gallon I would appreciate it
Daybreak
2 Star Admiral
770
Va
Go into any Deere dealer and have them order it. Nothing else needs to be done. They will get it in for you. They are a dealership. They might not even have sold any, but, they can get it in for the right price.
Greenpartstore has nothing to do with Deere. It is a profit making enterprise which sells deere stuff for a price.
Deere products sold at Deere dealer. It's not a argument. You just need to get the facts straight.
Go back to a Deere dealer and have them order it.
BeerCan
Rhea County TN
Not arguing, really, just looking for a good deal. It was not clear in my post but it's $34.60 from the deere dealer in Athens TN https://id3eservices.cdkglobal-es.net/mydealer/#/PFWF3024/public/01/01/shop-for-parts?shopForPartsPagination={"sort":"partNumber","direction":"asc","page":0}&shopForPartsFilters={}&shopForPartsSearch=TY26661 . I was posting the online stores because you said it was available there and that is what I found.
Look, I was posting another option for users if they wanted. I said in my post it was more expensive than the Deere product. I'm interested because it's 15w40 and not 10w30 and thought others might be as well. Clearly not "twice the price" in cost.
I'll go back into lurk mode and refrain from posting stuff "until I get my facts straight". jeez
Light in the Dark
5,938
MA
I've been jerked around by the closest JD dealer over the same thing. They would only take my order if I committed to an entire case... and each bottle was over $30/ea (pre-covid). No idea what they ask for it now.
Whether the dealer can or will order for you, is up to them. Not everyone has a JD dealer by either, so thanks for the link to a potential source for something else that might work.
BeerCan
Rhea County TN
JD dealers around here don't really want to talk to you if you are a homeowner or a hobby farmer :) That's why I own a Branson and an Antonio Carraro. :)
Just picked up 2 802A. Generators have changed a lot since I've been in LOL and I was a mos 52D
