MRAP Alum. black wheels and Michlen 395/85R20's for LMTV ?
1951M1078
185
Glendale,AZ
Is their a SS member to get MRAP Alum. black wheels and Michlem 395/85R20's from ? Or just go to the net. ?
Thanks, Randy
1951M1078
185
Glendale,AZ
After a private message, I need to ask the a question. Some time ago I was told the MRAP wheels would work on a M1078. Is this true or not ? If its not its ok,I just don't need to buy wheels.
98G
Former SSG
4,424
MRAP rims are hub centered. The M1078 uses tapered bud rims, lie the M93 9series 5tons do. As much as i want to sell them to you I really don't think they'll work.*
I know for a fact that M1078 rims work on 939series trucks, and that MRAP rims will NOT work on 939series trucks.*
I suggest confirming fitment before proceeding.
mkcoen
381
Spring Branch, TX
Wheels from the Caiman MRAPs will work on the LMTV. I'm not sure if they came in aluminum though. The one set I had were steel.
1951M1078
185
Glendale,AZ
Just got off the phone with Jeff at ,War Time Fun. He has the Alum. wheel. With a new Goodyear MBT $780 without the run flat but with the bead lock and CTIS . More that I want to spend now but their out their.
NDT
6,491
Camp Wood/LC, TX
Caiman MRAP wheel will work on FMTVs, just need 40 rather pricy special lug nuts. (Thread here on this) These wheels have not been sold gov't surplus that I know of, they came from the two scrapyards that cut up BAE's stock of undelivered Caimans after the drawdown.
Jbulach
2,184
Sunman Indiana
You need the oddball 11-1/4" MRAP bolt pattern, not the common 13-1/4".
Then as stated above you'll need special lug nut or have the holes in the wheel chamfered.
I have heard of both bolt patterns in steel and aluminum here on SS.
86m1028
17
Murphy TEXAS
Do you have pics of these ?
I bought a set of wheels & tires from the place you mentioned.
I have no use for the wheels.
profo
73
jeanerette,la
The Mrap Caimen aluminum rims that have the same bolt pattern as a standard m939 truck that are made by Hutchenson WI-1184 do fit the LMTV without machining. The M939 as in my M927a2 series truck you have to machine the lug nut taper using a 82 degree countersink on the reverse side of the rim for the the DISH out on the rear of 900 series. You must use the special lug nut for both.
:grin:
coachgeo
3,461
North of Cincy OH
The Mrap Caimen rims...
rewrite??
The (11 1/4 bolt circle?) Mrap Caimen rims do fit the LMTV and the M939 series trucks. On the 900 series you have to machine the lug lug taper at 82 degrees for the the DISH out on the rear of 900 series. Use the special lug nuts for both (900 & FMTV?)!
don't want to be grammar police.... it was just hard to read for solid clarity without punctuation. As edited above.... is this the intended info you wanted to get across?
86m1028
17
Murphy TEXAS
:grin:
Are those, the wheels you got from me ?
Do you have any better pics with them mounted on your truck ?
profo
73
jeanerette,la
yes but thats the only picture so far, I can get another once it stops raining been raining for days here! Aircraft stripper and alot of buffing!
