coachgeo
- 3,461
- North of Cincy OH
Front axle on this truck was so sweet at one point in its life... it needed no shims.... but ..... that won't last forever and may need them this go around (almost got that far while doing the high speed 3rd conversion' then like pointman discovered needing the 2 axle seals per side.. grrrr. Had pre-purchased seals for a hub rebuild.... and stupidly assumed these were part of that. My fault for assuming.
Anyway..... I searched a good bit but running dry... granted most that search today was on a dial up speed sllllloooow processing computer in the shop Almost threw it across the shop
Tried to find the thread in here where i swear someone mentioned the thicknesses pointing out they probably could be made. Can't find that thread either.... grrr. If folk agree they could be made not too difficult, I will need dimensions (ID / OD ) cause I've none at all to measure.
Much thanx in advance
