Injector installation (nozzle direction)
fpchief
220
South Alabama
I took great care removing my injectors and marking what hole they came out of. Took them to the shop and they cleaned and tested them. Got them back and no more tape on them for what hole and the shop said it does not matter. My thing is doesn't it matter what direction the fuel is shot out of the injector? The TM says basically remove injector and to install, put a new gasket on it and install it and makes no reference as to how to orient the holes for the spray....
Any advice?
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
All the injectors are the same, and they'll only fit-up one way. Especially since you just got em tuned, shouldn't make any difference which goes where. I'd suggest you anneal the copper washers that seal them to the heads before reinstall (if you haven't bought new ones). Also, a 12 gauge shotgun bore mop works great for cleaning out the pockets the injectors slide down into, and remember that the torque spec should be in INCH pounds (some TM's have the spec listed in foot pounds, which will snap the hold-downs.) - MN
fpchief
220
South Alabama
Great info and thanks. I found I have a cracked return line T so I am dead in water till I find one of those.
Menaces Nemesis
262
Denver, Colorado
fpchief
220
South Alabama
IMG_20180906_074751_01.jpgIMG_20180906_074756_01.jpgWas busy installing the new injector lines and was attaching #6 to the nozzle and looked over and saw this...**** good way to fall backwards off the truck.
