dirtyfingernails
- 4
- 0
- Gainesville, FL
Could someone tell me the width (outside tire to outside tire) and length (nose to rear) of the M1009? I need to see if it will fit on my trailer. thanks!
Steve
Steve
took mine over a scale today at the dump, with a ful ltank of fuel, no cap, me , a winch and my range gear, 6279.clinto said:Wow, they weigh 6200?
Olly Hondro, mind me asking what the C02 tank is for?Weight of a mixed/matched M1008/m1009: steer axle 3120 lbs, drive axle 3000 lbs. This is the CAT scale nomenclature.
Thats an M1009 Blazer w/ M1008 pickup axles.
No top,
No tailgate.
No back seat,
trail doors
+rollcage
+ 2 spare tires
+ CO2 tank
Full of diesel
Me in it (after lunch).
Airing up the tires (instead of an air compressor)Olly Hondro, mind me asking what the C02 tank is for?
thanks,,,Honda
Any way you look at Blazers are big heavy boat anchors , but they are also so prone to rust they lighten themselves over timeThe civillian Blazer had a lighter curb weight - is the majority of the weight due to the 6.2? What can be done to lighten a M1009, if anything?
EDIT: I know that this is resurrecting an old thread, but it shows I used the search button, keeps all the info in one place, and doesn't pollute with more of the same threads.
That is correct. The CO2 is stored in liquid form, like propane, so there is alot more "air" available than a scuba tank would store. Regulated at 115 psi, can fill a 37" tire in less than a minute. Also can run pnuematic tools = my favorite thing to do. Well, second favorite.Airing up the tires (instead of an air compressor)
Sent from my LM-G710 using Tapatalk
Putting the Blazer on a diet is a formidable task, with unsatisfying results. You see all I have stripped off mine and its near GVW, well, would be if suspension was stock. There are multiple threads on the interweb with titles like "K5 on a diet" that will give you ideas. Some are difficult to implement e.g. a plexi windshield.The civillian Blazer had a lighter curb weight - is the majority of the weight due to the 6.2? What can be done to lighten a M1009, if anything?
My fully loaded 1009 tips the CAT scale at 7777 with me in it.My M1009 also weighs in at 6000 lbs. Mine also has 1-ton axles, H1 wheels w/ 38" tires. They add some weight, but not sure how much over stock.
I have driven it onto the scale at work several times. I never weighed a stock one.
