My first MEP generator (MEP-802a), new issue
Hi everyone! First off this site has been a wealth of info, as I'm just getting started with MEP generators and .mil surplus in general. So big Thanks to all the contributors out there!
I picked up a non-running MEP-802a off Craigslist for cheap. The previous owner indicated it had a broken master switch and a fuel leak from the tank area. All the pieces were present minus batteries, so I picked it up.
This unit is older with the plastic master switch shaft. I was able to fabricate a new shaft and save the switch. The fuel leak turned out to be the return line, which was broken at the tank fitting and on top of the engine. $15 in parts and some new batteries and she fired right up and got to work making electricity. I added a fuse to the A1 regulator and have a MOV on order.
Everything works except the oil pressure gauge. It is stuck at 50 psi and I'm not sure if it's the gauge or sender. Does anyone know what the ohm range is for the sender unit so I can test it?
Thanks!
Thanks!
