- 1,200
- 457
- 83
- Spartanburg,SC
lol.. you wrote it so odds are you remember everything.... for everyone else... that info was nearly two pages back and written 3 days ago thus it is not stuck in folks heads as much as it is in yours. I wish was granted with photographic memory.. but am not probably most in here don't have it either. Thus the question asking for clarity on that point.
hmmm....so after your last test and it went back to #2 on keypad..... did you only have second gear again or is is just showing #2. That was not specified and readers should not assume.
Maybe you have a bad TCU?
Don't recall but does the tranny default to 2cnd as a limp mode? If so; maybe it is not speed sensor related but actually something else is up and your getting put into a limp mode? could the previous destroyed speed sensors have left little shrapnel in there causing problems?
Transmission will not shift out of 2nd gear if the sensor is disconnected. It shifted normally after reconnecting it and erasing the 25 11 code. It's not shrapnel from the last one; it won't shift, at least on mine, until it sees a good speed sensor.
