- 14,619
- 4,740
- Buchanan, GA
You can view the page at http://www.steelsoldiers.com/content.php?4-MEP-WIKI
I am new here. I have a MEP-002A my generator only has 2 electric pumps and 1 injector pump on side of motor mechanical pump But I think the MEP-002A and MEP-003A are the same electric fuel pumps. I would check for 24 volts at the pump that is not running. The aux.pump just pumps fuel from aux fuel tank to the on board fuel tank on board has a float in it that turns aux pump on and offJust purchased a MEP-003A and I think the fuel pumps are bad. Well I think two of the three are bad. Question, does all three pumps have to be working to make the generator start? I know the aux. pump is working. I purchase a pump from the auto parts store which is 24 volts and I have 24 volts coming to it. But not coming out I grounded it and still not coming out. I need some help with this. Is there any fuses in the lines for the pumps?
Thanks
was hoping for a suggestion...I ended up with a fuel rated well nut that did the trickSo................ What can we help you with?
I would start your own thread. Where you are now, is not going to bring you any help.Ok I have a question about an 002a generator I just bought, it cracked and every thing worked as it should and I was testing the out put lugs and hit l1 and l3 it made a small spark and now it's not producing any thang . So what did I do to it.
