below thread has good info on the alternate ones linked. there is now another very similar than one linked above on same site that looks to have a little bit more metal (round holes instead of slots) thus may be stronger. few bucks more each. I will be using ones previously linked for door handle too... removable nobs on these makes them a door handle... so you end up with it all matching. Though going to electric windows.... I do hope to find a way to be able to slip crank on in case electric ones goes down. Got other priorities first though.OK. Thank you very much for your help! I will try the thin plastic ring and also the alu handles from online market...
Thanks a lot from Italy!
I would not buy these. Poor design bad fit and not long before they wobble off or become stripped. Waste of money!The door handles are a standard 7/16" round shaft with 16 splines. You can find a lot of handles that will fit it, but I'm not sure how many will have a protruding nose that will fit down inside the door panel.
I don't plan to use them, but I bought these out of curiosity to see if they fit, and they did. https://smile.amazon.com/gp/product/B00OPZ49YO/
can't disagree...... will report back when I finally get them installed. Based on your report and another I do plan to:I would not buy these. Poor design bad fit and not long before they wobble off or become stripped. Waste of money!
