Jayco36REQS
- 2
- 16
- Orlando/FL
Hey... I have a M923A1 that won't start.... It hadn't been ran in quite awhile, and the last time I drove it, it was sluggish and slow throttle response until it got warmed up. I'm guessing the fuel was getting bad.. (after thought now)
- I've replaced the main fuel filter
- Drained the tank and put in clean diesel - No Start
- Replaced the PT filter screen - No Start
- Disconnected the fuel lines from the PT, and hooked up a transfer pump into a clean 5 gal jerry can of diesel, turned on pump to apply pressure to the inlet of the PT - No Start
- Cracked open the Fuel T-Line going to the front and back of the motor... fuel sprays out
- Cracked open the Fuel line fitting at the front of the motor... fuel sprays out
What is the next step??? I'm guessing the next step is to remove the injectors? I'm definitely NOT a diesel mechanic, and have never cracked open one of these motors. I know the injectors are inside.. and have a timing, pushrods, adjustments, etc....
Is there any field trick to test, or clean the injectors without removing them?? Maybe crank straight Sea foam in it while trying to start it??
HELP?!?!?!
HELP?!?!?!
