Hello
I joined a few months ago before i started building this truck, as i knew i wanted these wheels to go on it and this forum kept popping up. I read around and saw threads about flipping wheels to get them to align as singles, and rolled the dice. Now i have front wheels that stick out 6" further on each side then my rear wheels. No one will make even a super spacer due to liability, which i can understand. - Bought as cab and chassis, shortened frame, rolled axle, built new frame to support bed, etc.
I called the wheel guy from WI and he has some that have 1.5" more/less offset, which would reduce it from 6" difference to 3" difference (1.5 in on front +1.5 out on rear) - this would require shipping new wheels, blasting, powder coating, mount balance, etc..
Questions for all of you - anyway to change out for a wider rear axle or narrow the front somehow ?
There a certain wheel or model i need to be looking specifically for to get this to work properly, or do i just have a monster truck that doesn't look as perfect as i'd like ?
Outside of rear tires sit 1-2" inside of rear fender flare.
I had to change out all of my lug studs to receive this stud piloted wheels, and now would look to get the rears to stick out a bit further somehow - open to suggestions.
