Accessing 4x4 and 2 speed locking cylinders.
Jamesm417
Alaska
Can someone tell me how I can access the 4x4 locking cylinder, as well as the 2 speed?
Is tilting the cab necessary?
Those components are not currently operating.
Thanks,
Jim
peakbagger
360
northern nh
I have not done so but believe you do need to tilt the cab.
In order to tilt the cab you need a set of tilt brackets. One of the members on this forum (Speedwobble?) was making reproductions and selling them. He had them listed on Ebay awhile ago but I didnt see any listings when I checked today.
I found a closed listing on Ebay https://www.ebay.com/itm/Cab-Tilt-Brakcet-Set-Unimog-FLU-419-SEE-/232710472050. I think Expedition Imports was buying it from the same person
Road Rage
9
Lampasas, Texas
There is a regulator in the center of the truck that reduces the air pressure for those two systems.
I have traced my 4x4 and Splitter problems to that point. I plan to take the regulator out and test the system with a regulated air source...
That regulator can be accessed without the tilt. If air is not coming out of that regulator, you will not be able to sift 4x4 or splitter.
monstermog
Billings, MT
To access the 4x4 selector switch to replace you have to tilt. There is a small access hole under the cab at actuator. Spray some LPS1 IN THERE FIRST. Be gentle it should start working. Dirt gets in there and won't allow it to move. The actuators are expensive.
joeblack5
244
State College PA
You can access the 4*4 cylinder and air related stuff from inside the cab by removing the panel inside the cab. See the thread I started for pictures. Good luck j
Jamesm417
Alaska
I was able to get at the regulator by removing the spare tire. It apparently just need a little adjustment, and all is working now.
Thanks for the replies.
tennmogger
543
Greenback, TN
Glad it's working again. That device sounds like the over pressure valve that holds back air to the secondary circuits (like 4x4 and lockers) until the preset pressure is reached in the primary circuits. A safety thing, insuring brakes get first choice of air. The 4x4 and lockers run on full system air pressure in a normal Unimog.
