papakb
- 1,183
- San Jose, Ca
I recently replaced the batteries in my M996A1 and after years of using Interstate 6TLs that only lasted about 28 months I decided to go with 24Fs. They are the same height and length as the 6TLs but a couple inches narrower so you can use your old battery hold down bracket with them. They have the same CCA ratings and come with a 3 year replacement that beats the snot out of the Interstates. I changed the routing of the cables to a much simpler path as you can see and you can use a quick disconnect jumper between them as a security measure if you want to. For whatever reason these 24F batteries come in 2 versions called North and South(????). One has flat top fill covers and the other has the old sytle raised fill caps. Look for the flat top batteries. Here's a picture of how this turned out:
Yes, they do fit into the original battery. I put some high density foam alongside the batteries but after several hundred miles of driving I don't see any evidence of the batteries moving. It does add some insulation to the batteries too.
