Max Bladwin
- 2
- 8
- Michigan
I need some help. My brain is in a fog from working 14 hour shifts for the last 3 weeks.
I have been working on tuning up a MEP-015a. I got the transducer and voltage regulator issues resolved. My remaining issue is the carb. I thought it a good idea to take it off and give it a good cleaning with carb cleaner. Well maybe I didn't get the best results. The adjustment screw on the bowl is looser then I would like and although I don't see anything obstructing the float shutoff the bowl fills with fuel to the top and leaks down the air intake. Is there an adjustment I'm missing? Should I give a good soak in carb cleaner? Any suggestions on what cleaner to use? What about a diagram of the carb assembly?
Again thanks. Long hours and me don't work so well. Although I have another unit that works like a dream in would like to get this one ready and use it this hunting season.
