- 1,212
- 447
- 83
- Guymon, OK
I have an Essex electro engineers A698 60kw load bank available...... pm for details
Z
thats almost as good as phone sex right there.... pm inbound
Z
it was intended as a funny, since I found the right tool for the right job, without having to enginerd it myself, thats what makes it goodHUH?![]()
Well I made a green building something like this great why doesn’t everyone actually use the generator for what it’s for running the houseI used your design in some way,Thanks!
View attachment 716856View attachment 716857View attachment 716858
so what do you suggest for a cheaper way? I will throw a 'pinch of safety' is required in.Well I made a green building something like this great why doesn’t everyone actually use the generator for what it’s for running the house
I really get the load bank thing I really do I understand but it seems like everybody put a lot of time and this load banks and money
Look on Craigslist for a free working stove/ovens, people are always trying to give them away. You can control the load by turning on more burners and the oven. Two stoves will give you more than a 110% load on a 803. Free controllable load tester.so what do you suggest for a cheaper way? I will throw a 'pinch of safety' is required in.
x 12, that would be a birdsnest of wiring.Look on Craigslist for a free working stove/ovens, people are always trying to give them away. You can control the load by turning on more burners and the oven. Two stoves will give you more than a 110% load on a 803. Free controllable load tester.
60kw + 10%, so say 70kw should do a good load.Thats great for an 803... but the last machine being talked about was a 60kw rated unit. Whole different ball game.
So why is it so much fun to make these machine work? I mean all we are doing is converting fuel to heat, but its oh so much fun.
I did get the proper tool for the proper job, just needs to be delivered the rest of the way home. Thanks Ziggy
.Started actually building my load bank tonight. I'm using an old Carrier 2 ton outdoor unit to house the whole thing. Its 240V motor and fan will provide all the cooling I'll need.
And here's the outer shell I'll drop the above contraption into:
I will of course remove the compressor and coil first. The breaker panel will be fitted into that rectangular space to allow adjusting the load.
I'll put 4 caster wheels under the bottom to make it easy to move around.
