- 2,883
- 1,490
- Czech Republic
Any idea about European ways of counting kills?
UH, I don't think that FRIENDLY FIRE earns decorations. Not on this side of the Atlantic Ocean anywaze.So, my question - does the mechanic get to put a kill marking on his toolbox?
Cheers
But if both planes are on the ground, and both are pilotless...... maybe an exception could be made!I think planes on the ground without pilot do not count as "kill"
"But, Sir, I just didn't know the gun was loaded ! ! !"Maybe I missed it in here, but a bit of information to keep in mind - most of the multi-barrel rotary guns on aircraft will fire if you manually rotate the barrels of a loaded weapon. No power need be on, and no buttons need be pushed. That appears to be what happened in this case.
Cheers
Your kidding, right? No your not. I started to say it sounds like an pre-1900 Gatling Gun, then read up on the things and found out that that is exactly what it is. With all the billions invested in these machines, nobody thought about adding some sort of safety pall? Must be cheaper than an entire new airplane...........
Cheers
