cowhock35
- 0
- 0
- Big Timber
I just got my first MV on Govplanet and am trying to make an ultimate cow feeding machine out of it. I'm going to mount a feeder on the bed and load bales with the crane etc, that part should be pretty easy and fun.
The truck on the other hand is certainly like no CV I've ever worked on. I have heard these are electrical nightmares and from the start mine has been a pain. I have a drain on the battery somewhere so I have to disconnect the terminals after I shut down, and the starter had the common problem where it would just click instead of turning over. I probably rushed in too fast and got a new starter and put it in, but it didn't solve the issue at all. When I hotwired the K1 relay north-south, it cranks over fine. Ive tried lots of different relays in that position, nothing seems to help. When I push the start switch and test the voltage on the signal wires, they are 24v, I can't seem to get that signal to shake or waver, even though it acts like a wire is loose in it when I try to crank.
So, I just bypassed the relay and hooked the switch up to the top and bottom terminals on K1 and it works great. Is there any reason why this wouldn't be safe? Passenger cars don't use starter relays typically, you just turn the key.
I would ultimately like to strip the electrical system down to just the bare bones, I am looking for reliability primarily. I don't need a chemical detector or blackout lights, and I defintely don't need a start inhibit that will prevent me from starting the rig if either the switch is pressed or the start inhibit relay is bad. I mean honestly, why would anyone want that. Just pinch a fuel line off with vice grips.....
Anyway, has anyone done a build like this before? I don't want to start ripping things out that it turns out are important somehow but I would love to do away with lots of the junk, specifically the start inhibit and the confusing battery cable routing, and all the pointless systems I will never use (blackout) but those systems are probably most easily eliminated by just pulling the fuse.
The truck is in really good shape, and my only other issue so far is that it starts worse than my old tractors. In 50 degree weather where my diesel trucks and semis would pop right off, this 3116 coughs and sputters and piddles around for a solid 10 seconds before it gets going, and its far worse in the cold. I would say its the equivalent of my 99 dodge 24v cummins when its right about 0 outside. Is this normal for these engines? I ordered a block heater and might put a pan heater on as well, but I'm a little worried it won't start at all if it gets actually cold. I'm in Montana, if this won't start in the -20 region its as useless as tits on a bull. Motor has 30k on it, visually looks pretty good on the outside. Never seen oil so clean in a diesel in my life.
