rolling18
- 75
- 28
- Portland, OR
Pushed red start button,... cranked over as usual but starter would not disengage!.... tried to get out to the battery and could not remove the battery cables.
Ended up melting right through the lead post/ clamps! Almost burned to the AGM batteries!
Replaced engine block mounted relay on the passenger side under the air box.. Same thing starter will not disengage disconnected battery to keep it from melting again.
What could be causing my starter to not disengage?
I have searched and only found posts about not being able to start.
It starts fine just just to starter will not disengage without disconnecting the battery.
Thanks in advance for any and all help
