Mr4btTahoe
- 65
- 28
- Indiana
FINALLY had some time to get out and work on the genny today. Its been a crazy few weeks as the company I work for is in the middle of a merger that all but wrapped up friday.
Anyways, hooked the batteries back up and toyed around a bit. Now that the fuel cut solenoid linkage is not bound up, the solenoid is definitely moving. Not sure if it's moving far enough.. but it is moving. Still no fuel out of the injection pump so I decided to dig into the pump a bit. Pulled the delivery valve holder/assembly and found the plunger to be frozen. I lightly tapped the plunger and it retracted so I hosed it down with penetrating oil.. bumped the start switch and it pushed back out and stuck. I repeated the process 20 or so times until the plunger moved freely while cranking. I reassembled the pump in reverse order.
After reassembly, I loosened an injector feed at the pump body and cranked the engine over and now I'm getting fuel out of the pump (before, there was nothing).
I snugged the line back up and hit the pre-heaters for 60 seconds as per the manual and cranked it over. Nothing. Very little smoke out of the pipe (more likely just moisture).
Where to go from here... ideas?
