'86 heater blower
crazzyrman
NJ
I have a 1986 hmmwv that the heater blower motor died it has the round output. Do the newer heater blowers with the rectangle outputs just bolt on in place? I can figure out how to modify the output to fit the round tubing.
86humv
501
Texas
Originals are not hard to find.
I have replacements
86humv
501
Texas
Hmmwv standard heaters only have round outputs.
If you need a replacement fan motor...Wanted is a good place.
TOBASH
3,497
Brooklyn, NY
Did you heater motor and your windshield washer die at same time? Do you have electrical gremlins?
You need to check power to plugs and switches, and maybe also look for surges in current.
MH), YMMV
BenDeez
Dennisport, MA
For what its worth- I just thought my heater motor died and started looking for new ones. After looking over my heater, cleaning the grounds, adding dielectric grease to the connections and making sure they were all strong, it worked again **. I also had a lot of mud built up in the hoses, maybe a wasp nest in one that was completely clogged.
**Do these have a temperature switch that shuts them down at a certain temp? I have noticed mine still will work great, then shut off by itself, then after I shut the truck down, it will start back up.
mack59
Lebanon, MO.
Help!! Looking for tm 9-4940-563-13&P Contact Maint. shelter & TM for Navy M4KN 4000K fork lift. Just recently acquired.
Any help would be greatly appreciated.
Thanks
BLK HMMWV
500
Pasadena California
Perhaps that question would be better asked on a Silverado forum. I'd also suggest a search of the TM section found here on the forums in the TM section.
dilvoy
25
San Francisco, Ca.
Also,
Am going to attempt to mount shelter to a 2005 Silverado 2500 HD 4X4. Any thoughts?
Bed rail height may be a tiny bit too high. Might need something like a couple of 2"x4"s laid cross wise in the bed to give good clearance. The CUCV Trucks had a tie down system for carrying the shelters. One crossed the front of the bed with a hoop at each side with long bolts and sleeves going down through the bed and into the cross brace of the bed. At the rear, sort of the same thing was done, but with no bar crossing the width of the bed.
crazzyrman
NJ
MH), YMMV
They didn't die at the same time but both died while I was having an overcharging issue that I finally got resolved & now I'm trying to fix all the other stuff I burned up while still running the truck.
TOBASH
3,497
Brooklyn, NY
So if heater is now OK with cleaning, why are you so sure wiper motor is not salvageable?
