5 ton FMTVs the front pulls and the rear rear pulls by default. The front tandem is a power divider like a normal commercial truck that only engages in mode for low range Which I think adding a power divider switch would be beneficial than always having to be in low range to use it. Especially since the FMTVs won't even climb my trailer in high range since the front tandem doesn't pull.Maybe your passenger side rears were spinning and you just couldn't see? Press the Mode button on the the shifter pad to lock the transfer case, light should stay solid. The LMTV / MTV series are similar to the M939 trucks, they power the rears by default and need some operator involvement to power the front axle. If I misread what you posted, I'll try to provide some advice.
This idea has been batted around.... that one of the two rears just tags along till activated.... by mode. This has been disputed cause well.... there is a differential in there...... if one was only set to be active or inactive.. you would only need a device to disengage/engage one of the two rears... there would be no need for a differential5 ton FMTVs the front pulls and the rear rear pulls by default. The front tandem is a power divider like a normal commercial truck that only engages in mode for low range Which I think adding a power divider switch would be beneficial than always having to be in low range to use it. Especially since the FMTVs won't even climb my trailer in high range since the front tandem doesn't pull.
This does not seem right. It is AWD and powers all wheels all the time by default, but it is a 60/40 split with more torque going to the rear. The mode button locks the center diff so it is a positive 50/50 and both driveshafts will turn.Maybe your passenger side rears were spinning and you just couldn't see? Press the Mode button on the the shifter pad to lock the transfer case, light should stay solid. The LMTV / MTV series are similar to the M939 trucks, they power the rears by default and need some operator involvement to power the front axle. If I misread what you posted, I'll try to provide some advice.
welll..... sorta when it comes to the "all the wheels all the time".... if not mistaken AWD Tcase also acts like a differential to a point so if front tires begun to spin...... it would NOT send anything to the rear wheels...... it would all go to the front wheels.This does not seem right. It is AWD and powers all wheels all the time by default, but it is a 60/40 split with more torque going to the rear. The mode button locks the center diff so it is a positive 50/50 and both driveshafts will turn.
Open differentials apply the power to the wheel with the least traction. So on a single axle, it goes to the wheel that is loose, not the one with traction. If you put another open differential in between the two axles, it too sends the power to the output (the axle) with the least traction, then that axle sends the power to the wheel with the least traction. The result is that the engine power goes to the single wheel with the least traction out of all four, in an All Wheel Drive (AWD) system with an open differential in the center (and open differential axles).If the front axle has no traction in regular drive mode the rears will not spin.
