Barrman
- 1,782
- Giddings, Texas
I have been blazing through some repairs to the Whistler the last 3-1/2 years. It started making oil in May of 2015. It sat for a while, the wiring rotted off so I couldn’t get power to the intank pump to check the boost pump seal. Then we had a hurricane. Life got in the way and such.
It now has a new front wiring harness and 3 new o rings on the hydraulic head area. The boost pump drive shaft seal wasn’t leaking. I changed the oil and can get it to run above 1500 rpms only. It is not making oil though. That part is fixed.
Fuel pump in the tank is making pressure. All 3 fuel filters are draining and bleeding clean fuel. It revs up to redline. Pretty quickly too. When it gets below 1500 rpm it will surge and sometimes hold around 1200. Other times it kind of winds down and won’t catch no matter how much throttle I give it.
I have had it running probably 15 minutes since the injector lines were off. I don’t think air in the lines is the problem, but who knows.
Any helpful suggestions?
Thanks and happy new year to everyone.
