nf6x
Feral Engineer
- 1,630
- 50
- 48
- Riverside, CA, USA
Hey there, everybody! I'm finally tinkering with my wrecker a bit after ignoring my green truck hobby for quite a long time.
The transfer PTO on my M936A1 wrecker is very hard to engage. I think that the shift lever may not be actuating the linkage on the PTO far enough, so I crawled under there to take a look at the linkage. Lever #5 looks bent out of shape in the right direction to interfere with engaging the PTO, so I think I should take it off and give it some love before I try readjusting the cable end.
Now, when I took out bolt #8, gear oil began dribbling out of the bolt hole in the PTO housing. I put the bolt right back in, since I was just doing a bit of exploration before setting time aside to do the job right.
Should it surprise or concern me that some gear oil came out of that hole? Is there normally something like a weep hole in the bottom of that (blind?) threaded hole, or should I be taking off the whole PTO for disassembly and inspection when I next work on this?
Incidentally, there are a couple of other things I might like to address on my PTO shifter. The lock #10 on the shift lever is hard to get a grip on without using a tool, so I'm thinking about welding a little bar onto the lock to give me an easier dingus to grab on the inboard side of the shift lever. The shift lever #6 is also a bit hard to manipulate because the tip of it is cramped in next to the driver's seat belt retractor. That might not be a problem any more once I have the linkage adjusted properly and engaging/disengaging smoothly, but I'm considering adding some sort of extension to the shift lever. Assuming I can do that without constantly boofing Soldier A on the shift lever while climbing in and out of the truck, that is. If any of y'all have tinkered with your wrecker PTO shift levers to make them more awesome, I'd love to hear about it.
