Hella h4 conversion or truck-lite style led?
warcow105
Lincoln Park, NJ
Since the retrofit source had the morimoto sealed7 1.0 on clearance for $75 each I said what the **** and got a pair. I have used morimoto hid projectors to retrofit other vehicles with great results, but these led units left me unimpressed. Hopefully their 2.0 version is better, but I'm not spending $250 each.
Between truck-lite style led and hella h4 conversion what would you choose? Overly blue light throws off my vision at night, but I found a set of Truck-lite knockoffs for under $100 that are 5600k color temperature which is better for me.
Thanks,
Mike
JoeJrTheBarber
21
Chicago, IL
If your talking headlights I went with a 24volt Truck-Lite "spotlight" and used them as headlights.
Work super well and were a 1/4 of what a dual beam "headlight" costs..
DREDnot
447
Phoenix, AZ
I went with trucklite headlites as I like the look of them.
If I wasnt, I would find some Cibie "E-code" H4 conversion lights. Hella is dot crap nowadays
I used to run hella E-codes that weren't bad, but Cibies throw light better IMO
gimpyrobb
dumpsterlandingfromorbit!
27,786
769
Cincy Ohio
For the cost difference, Id go with the H4 conversion. Ive had both and the led is nice, but not worth the price difference imho.
warcow105
Lincoln Park, NJ
I won't be putting spotlights in as headlights, seems a bit rude to the other drivers lol.
I was mainly looking at the truck-lite that has the split across the center.
Mike
papakb
1,194
San Jose, Ca
I've been running a pair of Hella H4's in my truck for 18 years now. Great lights, 24 volt, and DOT compliant.
pjwest03
37
Vestal/NY
The H4's work perfectly well for me. The price of the LED's is too much for not enough gain over the H4. The price difference buys a lot of H4 bulbs. Just running the H4's is like upgrading from kerosene lamps.
warcow105
Lincoln Park, NJ
I will give one of the h4 conversions a shot. I need a lot of light that isn't blue. The beam on these morimoto sealed7 1.0 units isn't that bad, but it's too blue which makes them harder for me to see with.
Mike
LouWon
103
Michigan
I did the Cibies H4, they where ok, but not bright enough for me with the original bulbs, so I used the 24V 90/100 bubs, much better.
LouWon
103
Michigan
I did not have any issues, the wires are pretty hefty, mind you someone might chime in and prove me wrong...
warcow105
Lincoln Park, NJ
Ok, got the cibies and 75w bulbs installed. A huge improvement over stock. I didn't do a comparison against the LED units I had installed which are fairly bright, but the fact that these aren't blue means I can see so much better. Might upgrade to the 100w bulbs, but for now I'm happy.
Thanks guys!
