Crazyguyla
- 124
- 43
- Altus, OK
I've been working on getting my brakes in working order. New master cylinder, air pack, steel and rubber lines. Working on getting each wheel working. Last time I moved the truck, had a wheel dragging. I finally was able to get the dragging wheel apart by unbolting the wheel cylinder and tapping it in while rocking the hub. The pads don't look burnt, really dirty. The wheel cylinder and the lower adjusting pins are seized. Ordered new wheel cylinders, but need to get the lower adjusting pins loose. I've tried penetrating oil, heat, more penetrating oil, and soft taps with a brass hammer.
Anyone have this problem before?
