Trailer Mounted MEPs
Light in the Dark
6,074
MA
Does anyone know the bolt size for the trailer mounted MEP units? I had dismounted one previously... and can't seem to find where I squirreled them away to. I definitely see them called out in the TM 9-6115-659-13&P, but not unique identifier info.
Thanks for your help.
hcso2332
26
Franklin, TN
I have some I can send you, do you need 4? I am away from the shop today so I can't get to them right now to send you the size.
Light in the Dark
6,074
MA
I have (2) LTT-TQG trailers coming in this week, and need to put (1) 803A on one for a pickup next weekend (the other will be used down the line). I appreciate the offer Bob. If you just want to measure them, that will help just as much (Can have some arrive next business day by MSC/Fastenal, etc). I assume they are Grade 5 minimum.
Guyfang
24,522
Burgkunstadt, Germany
THREAD CLASS2A
THREAD DIRECTIONRIGHT-HAND
THREAD LENGTH1 1/4 INCHES MINIMUM AND 1 221/500 INCHES MAXIMUM
FASTENER LENGTH1 86/125 INCHES MINIMUM AND 1 3/4 INCHES MAXIMUM
HEAD STYLEHEXAGON
HEAD HEIGHT0 151/500 INCHES MINIMUM AND 323/1000 INCHES MAXIMUM
WIDTH BETWEEN FLATS0 92/125 INCHES MINIMUM AND 3/4 INCHES MAXIMUM
END ITEM IDENTIFICATIONMRAP RG-33; MRAP BUFFALO MK2A2; MEDIUM MINE PROTECTED VEHICLE - MMPV
NOMINAL THREAD DIAMETER0 1/2 INCHES
THREAD QUANTITY PER INCH13
MINIMUM TENSILE STRENGTH150000 POUNDS PER SQUARE INCH
SURFACE FINISH63 MICROINCHES THREADS
MATERIALSTEEL OVERALL
MATERIAL DOCUMENT AND CLASSIFICATIONSAEJ429 GRADE 8 ASSN STD SINGLE MATERIAL RESPONSE OR STMA354 GRADE BD ASSN STD SINGLE MATERIAL RESPONSE OVERALL
SURFACE TREATMENTCHROMATE ZINC OVERALL
SURFACE TREATMENT DOCUMENT AND CLASSIFICATIONQQ-P-416,TY2CL3 FED SPEC SINGLE TREATMENT RESPONSE OVERALL
THREAD SERIES DESIGNATORUNC
This is for the screw. And its grade 8.
THREAD CLASS2B
LOCKING FEATUREPREVAILING TORQUE WITH NONMETALLIC INSERT
LUBRICATIONDRY FILM LUBRICANT
NUT STYLEHEXAGON
NUT HEIGHT0 579/1000 INCHES MINIMUM AND 609/1000 INCHES MAXIMUM
END ITEM IDENTIFICATIONTORPEDO, MK-48; GENERATOR, 15KW, DIESEL, MILITARY STANDARD FAMILY; MISSILE, TOMAHAWK; AIRCRAFT, (AC-130H, MC-130H, EC-130E, HC-130); NSN 4210-01-486-1035 TFFT (TACTICAL FIRE FIGHTING TRUCK);2320-01-097-0248,2320-01-097-0249,2320-01-100-7672,2320-01-097-0260,2320 -01-195-7641 HEMTT (HEAVY EXPANDED MOBILITY TACTICAL TRUCKS); MRAP AUV RG-33
WIDTH ACROSS FLATS0 92/125 INCHES MINIMUM AND 94/125 INCHES MAXIMUM
TEMP RATING250 DEG FAHRENHEIT NOMINAL
THREAD SERIESUNC
NOMINAL THREAD SIZE0 1/2 INCHES
BEARING SURFACE TYPECHAMFERED OR WASHER FACED
BEARING SURFACE FINISH125 MICROINCHES
MATERIALPLASTIC POLYAMIDE LOCKING INSERT
MATERIALSTEEL NUT
MATERIAL DOCUMENT AND CLASSIFICATIONSAE J995, GR 5 ASSN STD SINGLE MATERIAL RESPONSE NUT
SURFACE TREATMENTCADMIUM AND CHROMATE OVERALL EXCEPT INSERT
SURFACE TREATMENT DOCUMENT AND CLASSIFICATIONQQ-P-416,TYPE 2,CLASS 3 FED SPEC SINGLE TREATMENT RESPONSE OVERALL EXCEPT INSERT
This is for the nut. Its a grade 5
If you want the tech data for the washers, got that too.
Please take a picture of the Data plates on the trailers. I want to look at something.
Light in the Dark
6,074
MA
I will, when they come in. Tentative drop date is this coming Friday. Thanks for the above info Guy. Time to go peek through the garage...
Light in the Dark
6,074
MA
Well I lucked out... I actually hid the set in the tool box of my own PU797C! Thanks everyone.
