I have 1982 m813 usmc model with rear lockers . I think my sprag is stuck engaged because I can't get up to speed and the truck shutters when put into third gear like its towing a trailer . I'm planning on dropping the front drive shaft and seeing if the problem goes away . If truck goes better I'm going to flush out the transfer case with diesel then next would trouble shoot air poppets . If the sprag is stuck does it do any harm if the front drive shaft is removed . What's the procedure for flushing transfer case put in diesel run and repeat thanks . Mike
