Dead Pilot's M36a2 Build
Dead pilot
135
Fallbrook, CA
After 6 plus years of the engine not being ran I turned her over. 1st time seemed a bit rough but then couple of other bumps I did seemed to be just fine. I didnt attempt to completely start her up and have it run since the fuel shut off lever seemed to be sticking and then I didnt have power to fuel pump or a radiator in. But just having the engine turn over was good enough for me.
Sent from my SM-N950U using Tapatalk
Dead pilot
135
Fallbrook, CA
Got some more good news today. The shop I took my radiator to get checked out yesterday called me this morning. I was a bit worried but he said it could be saved only 4 leaks and only $40 to have it repaired. Now just have to get new hoses. Getting closer to having her running.
Dead pilot
135
Fallbrook, CA
Just having her turn over yesterday got me all excited and then the good news on my radiator makes things even better. I was thinking I was gonna have to have it rebuilt or worse find a new one. But luckily that wasnt the case. So this next week I'll be getting the coolant system all done up and change the oil and new filters all around. And fix the sticky fuel shut off lever. That way i can let her run when I get her ready to start again. I cant wait haha
71DeuceAK
407
Fairbanks, Alaska
I once looked at rescuing an M925 (Who later turned out to have a loving owner and was not left for dead in the junkyard she was at) and remember the thought of "When the weather warms up, I am sick with anticipation and dread at trying to have her make smoke and noise for the first time".
Tracer
13,843
Hawthorne, NV.
I'm shooting for by the end of next week. Just depends on when I order the parts and when they come in.
Dead, keep us posted. We hope your first start goes well and she purrs like a kitten!!!
Dead pilot
135
Fallbrook, CA
I'm hoping for good clean start up when it's time. I'm gonna try and record it so I have record of it.
But for today's progress I have the alternator installed. Had to modify the stock bracket for the leece neville 12/24 alternator that came off a 915 but I got it to fit and able to use the stock size belts. Now I just gotta figure out the wiring of it.
Can it be ran without a 12v battery for right now till I can get a battery for the 12v side?20190124_105747.jpg20190124_105759.jpg20190123_123655.jpg
silverstate55
Unemployable
873
UT
WOW fantastic work! Please keep the pics coming, you're doing a GREAT job!
About 2 years ago I sent in a Deuce radiator to my local "GOOD" radiator shop; core was shot, so aluminum replacement was $750 and brass was $900. Prices included re-attaching all sheet metal so it would be ready to install once returned. So I'm glad that yours was able to be repaired and for a good price!
[thumbzup] [thumbzup] [thumbzup]
cattlerepairman
3,264
NORTH (Canada)
The part that potentially sees high voltages is the regulator (mechanical energy goes in but no current flows out). I am not an expert on the mil spec alternators. A regular 12V car alternator is "expected" to survive being run without being connected to the batteries. Disconnecting the wires while running is another story.
I would probably just run 2 wires from the 12V side to any 12V battery (even if you park your pickup or car alongside the M36 and connect the two wires to it, or even pick up a $15 battery from a junk yard), just to not risk damage to a really expensive piece of kit.
orren
25
Live Oak, Florida, USA
Bob,
Great looking truck. I have a M36A2 in woodland camo with a tan top. Maybe
we could trade tops? Would rather have the woodland camo top but
couldn't find one so had to settle with the tan.
Are you interested? Any ideas to make it happen?
Thanks,
Orren
Dead pilot
135
Fallbrook, CA
Bob,
Thanks,
Orren
I just painted my top it started of as a tan top. It ends up matching the truck better. And that's how some of them were done when these truck were in the service. Well I know for sure the newer ones cause that's what we did so I'm sure not much changed
orren
25
Bob,
Are you happy with the paint you used? If so what brand and part number was it and where
did you get it?
Thanks for your help,
Orren
Dead pilot
135
Fallbrook, CA
Bob,
did you get it?
Orren
I used gillispie paint ordered from http://www.rapcoparts.com. I ordered quite a bit of paint since I'm repainting my whole truck. My color codes are probably different then yours unless you are using the 4 color merdc or the 383 3 color. Either way these guys have almost every color code that military trucks used.
Dead pilot
135
Fallbrook, CA
Well had a minor set back today. All the plastic return fuel lines are pretty much shot. So I have to go through and replace all that before I can attempt a full start up. Guess its time to start digging though the site and see what option I have.
