Most sealed batteries are sealed not with the consumer in mind. With time fluid evaporates and the low level is what kills the battery.If it is a sealed battery,(Of any type), Then no, there is no maintenance required.
That is the whole point of the battery being of the low maintenance type.
They are specially vented. (for pressure evaporation).
A good low trickle charge 'intelligent' battery maintainer is is a good idea to leave attached.
They are usually (Should be) Lead acid, Gel, and A.G.M. Suitable.
So youre saying that there is no liquid in these batteries?It's an AGM absorbed glass mat battery. All they need is an AGM maintainer connected 24-7-365 and they will last 10+ years.
My understanding is that the liquid is contained in a paste kinda like oil is contained in grease.So youre saying that there is no liquid in these batteries?
So youre saying it is a gel.My understanding is that the liquid is contained in a paste kinda like oil is contained in grease.
These are probably the best, most robust battery's I have ever seen or worked with. Properly take care of, they will last at least ten years.It's an AGM absorbed glass mat battery. All they need is an AGM maintainer connected 24-7-365 and they will last 10+ years.
