FirstGen FBody
- 1
- 8
- pa
Wide enough the antennas don't rub on the back cover Just under 89 3/4" at widest part off offsets, rear body is 83 1/2". Rear side reflectors about 84 1/2", door handles roughly 87 1/2-88" Mirrors way more didn't measure....... Take your pick.You have offset mounts on both sides right? Do you know how much wider they make the HMMWV?
thanks
Never thought of that, but then that would defeat the purpose of having them wouldn't it? LMAO, you know I was just looking at my pic to see how they would be in my mind facing aft, i never noticed after how long since I put them on, one is taller than the other....... I'm very observant......LOLOffsets can also be pointed facing backwards instead of sideways.
I drive it only on the weekends, so i pull it out thursday night unfold the mirrors then put it back in on sunday.You're welcome, but the mirrors are the widest part of the vehicle. Do you plan on folding them every time you park?
did not know that, thanks for the infoOffsets can also be pointed facing backwards instead of sideways.
Heh, that's my truck.Can a tire on an rhino tire carrier clear a offset antenna base when fully swung out?
a setup like this.
thanks
