dbjra
- 0
- 0
- smithfield, NC
Hi anyone
i am new to forum and hope to get help troubleshooting mep806A 60kw generator. i got unit to start and run as long as i hold the start switch on. the starter doesnt keep starting because i had to manually close the contacts on the starter solenoid. once it fires up, of course i release starter contacts. unit runs only if i hold starter switch on. once i release switch, the unit shuts down. not sure if the two issues are related. was trying to figure out if any of the faults might be causing this problem. all the components (relays, genset box are new and everything is in good shape). a few things might be in play----it has low fuel, but definitely a few gallons and i dont hear any primer pump in prime position ( the aux pump runs great). not sure if it even has electrical pump or just the mechanical when cranking.
thanks
dean
thanks
dean
