nyoffroad
- 718
- 93
- Rochester NY
Dance class??
Bearings will have no effect, the drag link may be the problem, have you checked the ride height? If the left spring sags that's going to change the ride height and just like if you put a lift kit in changes the angle of the drag link and that will move the wheel off center.I installed the Off Road design steering brace on my steering box when I did my front end repairs. Everything is tight, I see no problem there.
Currently my course of action is going to be replacing the bearings and seals on the driver side and redriving it to check if that makes any difference. I've also got a new drag link end coming.
